Originally Posted by
kenmeade
A black carbon/oil mixture leaks from every muffler joint including the center section at both ends, main central bolt head and rear nut. The leaks make a mess which is hard to clean - plus it looks like crud. I wanted to weld it solid but the center section is SS so that won't work. Tried steel epoxy. Tried high tem silicon gasket seal. Tried small "O" rings in the center SS joints. Maybe there's tricks that make one of those work? Any ideas?
A friend said there's OS muffler that will fit. Any info there?
Question. Is the center section of the muffler designed to "tune" the exhaust system?
Is anybody making a replacement part that can be welded to the body sealing it for sure?
Thanks - Happy New Year!
Ken
An OS 46AX or FX muffler is a perfect fit and will end your muffler problems. It's also less noisy than anything else I've tried.
