RCU Forums - View Single Post - New Evolution 10cc gas engine
Old 12-31-2014 | 07:18 PM
  #1910
kenmeade
Originally Posted by the pope
Generally things workout cheaper if you can get stuff off the rack . I couldnt see evolution getting stuff made especially when there's something thats going to do the job thats nearly the right size . I have one of these engines with the macs muffler on it and dont know where the oem one is to measure ( always a option for you and may even be cheaper if you need to buy the tube and get someone to weld it . Most fabricators and welding shops have a minimum charge to keep time wasters away . When I was doing this for a living I would always say that I may fix it or f@#ck it just in case the stuff wont weld properly which maybe the case in this instance .If it was me I would get the macs muffler and leave all your troubles behind . Good luck with what ever path you choose from the pope
Just checked the Macs and they said - "Evolution .52-.60NX & 10cc GX(gas) (MACS Product Does not guarantee this muffler when it is used on the Evo.10cc
GX(gas) or other gas motors)"
Plus they want $49 and shipping. Thanks for the idea and it's a good one. I'll call them to see what the problem might be in using one on a gas motor. But you had success so will see. I understand the welding situation.
Does you motor still have black goop exhaust? I've been using a "blend" oil. Will all synthetic help there do you know? Ken
