You have too much nitro in the fuel. It will run best with about 10%-15% nitro in the fuel. The noise you are hearing is likely detonation. When the engine is set up correctly, you will want it to run in the high-9,000's at full throttle on the ground when leaned to just rich of peak RPM.
