RCU Forums - View Single Post - BVM Electra 10s or 12s
Old 01-05-2015 | 10:42 AM
JackD's Avatar
JackD
Originally Posted by KFX450
I think I saw a pick of yours on the web somewhere before with that set up..BV sells the TP saddle packs correct? 3) 4 cells..If I did that how would that go?? one on one side and 2 packs on the other???
BV sells the TP saddle packs. Also Dinogy. And yes, you need 3x4s packs to charge in parallel. 2x5s + 1x2s need to be charged separately
The way the fit in the aircraft is: 2 on the sides (same as your 10 s), one between the inlets, behind the landing gear door. That is the best way to balance it.
Let us know what you end up doing!
Later
Jack
