Originally Posted by
drjoeshmoe
thanks, I will try the cracked gas cap tomorrow...., its a brand new carb and brand new air filter. The carb does not have a choke.
The fuel line was new but it was very tight to feed threw the grommets, a drop of dish soap was used,., I ordered some other fuel line, I will give it a try tomorrow as well.
thanks,
Joe
Yea,with the choke,try taking off the filter housing,an mounting carb.with out it,But dont run it on the buggy on the surface.
If you can do that,then cover carb. half way by finger.If you get fuel drawl.then it could be the other mention.
Also,it sounds like the needles isnt opened up enough.Thats another matter that needs to be walked through.
