Originally Posted by
drjoeshmoe
I am new to this but assumed the line close to the priming bulb was the inlet as it appeared to draw fuel in...I noticed what I thought was the return line sucking fuel/air,....switched them...running good with No stailing..
Thanks guys for the help!
Its a bummer when get used stuff were other folks had tampered with,I work on peoples lawn equipment for
xtra side money,I run across alot of that.Its usually the small stuff that gets you!..
Anyway,Im glad you figured it out.
