RCU Forums - View Single Post - Help....... tail rotor problem?
Old 10-12-2003 | 12:05 AM
ShotgunTC88
Default RE: Help....... tail rotor problem?
You could be running your engine a little lean, Sometime that will make the tail wag after it gets hot (couple minutes hovering) and starts to miss
Try richining the engine up on the low and high side an 1/8 a turn at a time to see if that helps
Shotgun
