Help....... tail rotor problem?
Got a Hirobo, not had it long and very happy with it, But its started doing something a little strange. After about 2 mins into the flight the tail rotor goes scatty. Then i land- Fuel up- another couple of mins of flight and it does it again. The batteries are fully charged. its got a Heading hold 2000 gyro. and theres no major vibration.[:@] Bit new to the helli world but been flying planes for 8 years, be very greatful for any help.
You could be running your engine a little lean, Sometime that will make the tail wag after it gets hot (couple minutes hovering) and starts to miss
Try richining the engine up on the low and high side an 1/8 a turn at a time to see if that helps
Shotgun
Shotgun
Thanks for the ideas but its more than jus a wag it goes mental! Is it worth trying to fly without the gyro to eliminate it?
