RCU Forums - View Single Post - mono-coat
Thread: mono-coat
Old 01-12-2015 | 06:01 PM
rt3232
Well guys I have done it got the stab in and straight, but the 30 min epoxy I had was bad actually set up in the bottles as it was old, my LHS is 25 miles away so with the bad weather ice roads (cold) we have had I went with the polly glue and the only negative I have found after curing it left a slight white line so I will use a long stripping (3") brush and paint it.
Now to the next step, the kit furnishe's plastic (no pin) hinges and tell you to C/A them in. A few years back I lost 2 planes because they split/broke and decided then not to use them again. So now I am thinking on pined hinges 5 in the ailerons 4 in the elevators and 3 in the rudder (I am not a 3D flyer) they just requires a bit wider slot.
Hope to have this bird flying by mid season as I am now waiting on other bits.
Thanks for all of your suggestions and idea's.
Cheers Bob T
