Anyone seen a pipe like this?
Even more interesting yet! Thanks ED.
The carb needs replaced. The previous owner had tried to add it to the back porch supports. I disassembled the carb the the airbleed hole didn't quite match up with the hole/groove on the barrel 'flap'. A little ingenuity and I got her running fine.
If an engine is being stubborn-as this one was- I work on both ends of the throttle range at the same time. I would have been however, much for efficient had I known then what I know now!
Nice engine regardless of the carb problem! I'm thinking of selling the combo with two S148 servos.
Jeff
