RCU Forums - View Single Post - Foam wings, mechanical retracts
Old 01-18-2015 | 12:11 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
I use a hole saw to cut the wheel well then I make a verticle grained balsa box in the core. The balsa box butts up against the spar. After the core is skinned the wheel well and retract box is opened up. A ply plate is fabricated to mount the retract and installed into the box. The exterior is finished off with some balsa. When joining the wing, a vertical grained balsa/CF joiner is used and butts up to the rear edge of the spars. Pictures are worth 1000 words.
ID:	2065058   Click image for larger version
ID:	2065059   Click image for larger version
ID:	2065060   Click image for larger version
