RCU Forums - View Single Post - Needle settings-- where do I start?
Old 10-12-2003 | 09:53 AM
Antique's Avatar
Antique
Default RE: Needle settings-- where do I start?
Check the diaphragms first, any stiffness means replacement..2 turns out on both is good for ANY gasser..It will run, then adjust from there....You will likely end up about 1 1/4 to 1 1/2 on both, depend on prop size...Best little twin around...
