VXL-3 esc?
So I keep getting a slow flashing red light on my esc. Low voltage? Check battery is still at 75%. It's been doing this pretty much ever since I bought it. Well I decided to check wires to esc and when I pulled the wires out of the esc. The female banana plugs that the motor wires plug into come out with the male plugs on the motor wires. I think this is what is causing the voltage drop. Causing the flashing red light. I plug the banana plugs back in and esc works just fine. Green light back on. Question is about soldering female plugs back into esc. I have done some searching and seems some of the vxl esc's have the slow flashing red light problem. I just don't want to screw up my esc. Any thoughts? Thanks.
Reason: spelling
