The fuselage up to this point was a one day build. Placing the servos one behind the other instead of side by side may work out better since that will keep the pushrods off of the bulkhead. The wires look a bit long and the ones that came with the engine are very stiff. The ones that came with the ESC are much easer to work with. Would it be worth while to replace the stiffer wiring?
