Calibrating an ESC with Transmitter.
When calibrating a new ESC with a Transmitter, and going from Hi throttle to Low throttle after plugging in your Rx, is it necessary for the motor to be plugged in ? I also assume that the throttle trim should be set to neutral, or centered ?
Ed
