RE: Phoenix Sukhoi Engine Mount Problem
Chris True & Volfy are correct, the reason for the hole offset is due to the thrust angle. The prop & shaft of engine will line up w/ planes center axis at the cowls end once mounted. The Manufacture, like other MF's take this in consideration on planes w/ large cowl/firewall planes. This is why the hole is & must be offset. Oh yea, the mounts are not crap, but to each his own.
