RCU Forums - View Single Post - Great Planes Sequence 1.20 Build Thread
Old 02-11-2015 | 05:24 AM
corch
Originally Posted by hook57
Re: the low profile 9551 servos JAS. If I may ask, since you have to cut the hardwood block to accomodate the servo wire what is your preferred method to cutting it? I picked up the 9551s for mine and I am concerned about damaging the cover while cutting/grinding it to accomodate the servo wires. . Really like the pushrod idea, going that route too, I take it any centering issues are programmed out with the TX? Thanks for any feedback you can offer.
Mark
I just used a razor saw, took off about a quarter inch cube from block, emory board to sand. Just be sure to glue the blocks down (thin ca the med ca fillet) and allow to dry (or kick). Did not have any push thru with 7/16 servo mounting screws. Did not damage the cover at all.
