RCU Forums - View Single Post - Skymaster F-18F
Thread: Skymaster F-18F
Old 02-11-2015 | 05:09 PM
stevekott's Avatar
stevekott
I've had good luck on sloppy press fits by cleaning the surfaces with alcohol after sanding them to give them a little tooth.
Then you have you choice of adhesives. CA will hold fairly well but you will still be able to disassemble it with some effort. For a more permanent bond you can use Hysol or JB Weld.
Good Luck!
