This gadget helps find the center of an aileron
Servo layout. These 255 servos are smaller than the ones it plane was designed for. Instead of using the balsa sticks supplied dubro simi flex rods have been installed.
A few images of the wing being built on the mag top bench. I never liked sticking pins in the balsa.
Wing tip ready for sanding. Would you believe that after finishing both wing tips I compared them and discovered that one had been shaped properly for a sailplane and the other shaped as though it were a tarus wing. Fortunately the scrap box has a piece of balsa large enough to make another.
This is how the outer wing panel was sanded to mate with the inner panel.
A small weight was needed to balance the wing.
The bare wing weighs 301 grams
Two levels were used to align the wing to the fuselage.
This wood plate was added in hopes that nylon screws will work for the wing hold downs.
