Originally Posted by
YellowBlueBird
Thanks for the comment. No plan to change the wire size. The wires that came with the motor are very stiff. The wires that came with the brushless ESC are softer and easer to bend. The same wire gauge but with more strands. Why isn't the fuse needed with a brushless ESC?
The motor in your kit is a brushed motor, a brushless ESC won't work. It has an extra motor wire. You must use an ESC designed for brushed motors. I recommend the 35 amp size.
The fuse is just extra weight and will blow at inconvenient moments. The ESC will shut off before a fuse can blow if there is an overload.
