RE: Great Planes 33% Extra Project
Ronk ... I have a 3W-100 that I want to use. Its the older version which is a bit heavier. I will probably have to move my batteries way back to balance but thats cool.
Lennyk ... I would be interested in more info about how you mounted the cowl. It must look clean not seeing any screws around the outside of the cowl. On wing attachement, I thought about installing some 1/4-20 or larger nylon bolts from inside the root rib, instead of the alignment dowels. Then just put some wing nuts w/keepers on them from inside the fuse.
What servos did you guys use and how many servos on each aileron? Im using JR 8411's for ailerons (2 each) and elevators. Using one HS 805 for the rudder w/DHS pull pull.
Thanks for the tips,
Chuck
