Doc, I'll experiment with the cable. Vertical, I've used the guide tube trick on several models, including the Snipe. It's the only way on a serious scale model. The problem is that the exhaust ring on the 770 blocks direct access to the end of the needle valve. The tube would have to be coming in at, at least, 20 degrees.
