RCU Forums - View Single Post - Great Planes Sequence 1.20 Build Thread
Old 02-19-2015 | 10:03 AM
hook57
My Feedback: (21)
I picked up two of these rampage, one was a bit more wrinkled than the other but not really too bad. A quick hit with heat gun followed by the covering iron worked nicely.
Heads up on the Rimfire 1.20, check that the prop adapter mounting holes align with mounting holes on the motor can. Of the two that I have, one is off by at least about 1/32". If I rotate it around only three holes will align. On the second one, it lines up better and I can start all four socket head screws. However, I cannot get it to seat (bottom out) on the motor. I'm going to check it with a feeler gauge to see what the gap is. I will not operate the motor in either case. Called service center regarding it and they are looking into. I suspect the prop adapters were misdrilled or the jig that is used is out of tolerance. My two 1.20s were purchased within the last month. Not sure if JAS has seen this or not on his. Just FYI.
mark
