RCU Forums - View Single Post - BJ CRAFT new plane Invitation...
Old 02-23-2015 | 05:07 PM
drac1's Avatar
drac1
Originally Posted by MTK
Scott, I've run the apc narrow blade 20.5x10 on the CDI/ GT33/ pipe combo. The gasoline I use is Avgas mixed with a good racing synthetic at 50:1. I got 7200 max rpm, an rpm number we don't hardly ever need or use. I also tried the 21x10 apc and rpm dropped off to around 6700 which was bunch. The engine just didn't sound happy.
One thing to keep in mind is the type of gas one uses will make a difference in maximum output. The same gasoline mix as above is what I generally use on the 33 turning the 20x10.5 Narrow. I get about 7400 on that set-up.
I ran premium auto gas a couple years ago (same oil and ratio) just because and got about 7800 rpm for the 20x10.5. I decided I really hated the stench of auto gas and didn't need the extra power so I went back to Avgas ever since and have no plan to change, ever again.
Hey Matt,
I was planning on running premium, but 7800 is not needed so I might just go with Avgas from the start and see how that goes. Running the muffler will be a little less RPM, but if I can get around 6900 I think that will be OK. Thanks for the info.
I've been using the Tech Aero IBEC for a few years on my YS cdi's. Saves the weight of an extra battery and not one problem.
Yes I have to agree, Avgas does smell much better.
