RCU Forums - View Single Post - SIG Biper Cub (Kit Bash)
Old 02-24-2015 | 11:45 AM
  #52
John_M_'s Avatar
John_M_
Ok, so does it bind at the hinges as it opens, or is it binding at the lower door seam as the door swings down... to get it to swing flat down the fuse side ( without the struts fouling, or the door handle holding it off ) the hinge pivot points need to be away from the fuse side, in other words the hinges need to protrude a bit past the seam so the gap doesn't close up and bind when the door is opened fully.
You can see how the hinge pivot pin stick out past the door seam.
John M,
