RCU Forums - View Single Post - SIG Biper Cub (Kit Bash)
Old 02-24-2015 | 12:35 PM
  #53
acdii
Yeah, the way the manual puts them, the hinge is inside the door, so the pin does not stick out, so it binds about 3/4 open. I figured out what to do with the doors, and instead of using hinges between the bottom door and window frame, going to use fabric for the hinges. Going to have it swing up, and will put a lock up on the wing to hold it open using the same lock that is used to hold it closed. I might move the lock down to the bottom of the door so it latches at the bottom instead of the top.
The Stab and fin are done, just waiting on the epoxy to set then put the fairings on, and sand the tail, then it is ready to cover. The wings need some shims done, then they are ready to cover too. Really liking how this came out, and should be quite an eyeful at the field.
