RCU Forums - View Single Post - Cadence - F3A Prototype
Old 02-27-2015 | 09:00 AM
Fixed Wing's Avatar
Fixed Wing
Made a little more progress. Following are descriptions for each picture:
1) Balsa sheeting edge trued, taped together, and shaped to size for each of the foam pieces.
2) Slow cure epoxy with added red dye applied to each of the skins.
3) Added coat of epoxy over CF strips on the wing cores.
4) Everything in the vacuum bags under 6.5 In Hg.
All foam parts will cure in the bags under vacuum for 24 to 30 hours.
Name:	Cadence Bagging (2).JPG
ID:	2076932   Click image for larger version
Name:	Cadence Bagging (3).JPG
ID:	2076933   Click image for larger version
Name:	Cadence Bagging (4).JPG
ID:	2076934   Click image for larger version
Name:	Cadence Bagging (7).JPG
