RCU Forums - View Single Post - Glens Models 78" Cap232 ARF
Old 02-28-2015 | 12:05 AM
  #38
Francis L M's Avatar
Francis L M
going to the wing i clamped to the wing the top ply where i will be
adding together with an added ply with the blind nut.
As you can see i measured the center so i can drill the hole for the nylon screw and blind nut.
After drilling the hole and adding the extra piece of ply i place it on the fuselage to try out a dry fit just to check if all was inline.
I have glued with epoxy all the parts and now the moment of the truth i have installed the wing and i have to say
it was well worth the had work just what a simple way to fasten the wing.
ID:	2077205   Click image for larger version
ID:	2077208   Click image for larger version
ID:	2077209   Click image for larger version
ID:	2077210   Click image for larger version
ID:	2077211   Click image for larger version
ID:	2077213   Click image for larger version
ID:	2077214   Click image for larger version
Name:	2015-02-07 13.48.52.jpg
ID:	2077216   Click image for larger version
Name:	2015-02-13 15.43.05.jpg
