Well after all that hard work that i have had to go through with the engine box and fire wall is because the fire wall is just designed
to sit in front of the engine box,when normally most of all the models would be installed inside with grooved around the engine box
if this would have been the case i would have not had gone through all this.
Well this is what you get when the model has not been designed correctly,so and here we go now i have to get the under
carriage sorted too.i have also noticed that the blind nut are rusty or shall i say corroded just unbelievable.
Where has this model been to have the blind nuts corroded?
After having a good look at it there is no support to the wooden plate which holds the under carriage i am quite sure
if i don't re enforce it the wood will simply come of on my first landing.
here you have a snap shot off the ply wood.
You can clearly see the corrosion on the blind nuts.
