And here you can now see why i did that big square hole at the under side of the fuselage.
So there you go job done.
The next thing i need to do is to fasten the canister and box it all up so all the heat goes down and out,
all the holes i made in the front of the F2 and F3 is for the air flows out with the help of thrust coming from the prop.
Hope you all are enjoying the build well going to carry on with build will be shortly.
Thanks for watching.
