RCU Forums - View Single Post - Replicating casting texture
Old 03-11-2015 | 07:04 AM
MAUS45's Avatar
MAUS45
I use liquid cement or Mr. Surfacer 500 or 1000. I use an old tooth brush to stipple the surface when I use the liquid cement and a sponge for the Mr Surfacer. Just depends on how rough the cast effect needs to be as to how much I rough it up with the brush or sponge. I have also used a dremel tool to get a cast effect as well by using a round ball cutter bit to bounce around on the surface I wnat to look cast. It takes longer using this method but looks good. I ahve attached photos of all three methods. 1st set is the liquid glue method, 2nd set is the Mr. Surfacer method and the last set is the Dremel tool method.
ID:	2080637   Click image for larger version
ID:	2080641   Click image for larger version
Name:	R After 2.jpg
ID:	2080642   Click image for larger version
ID:	2080643   Click image for larger version
ID:	2080644   Click image for larger version
ID:	2080645   Click image for larger version
ID:	2080646   Click image for larger version
ID:	2080648   Click image for larger version
