Originally Posted by
MFLOOD3800
gtm,
Though the rudder will work ok with enough air flow over the surface, once you slow it down, youll need control. Plus at beginning of take off youll need to turn that thing to the right..... I suggest ditching the scale location and installing a tail wheel off the rudder/fuse (easy fix). I remember meeting you in Tucson. "Hormel Food"?
Marty,
I put all mine in the scale location and prefer them there. By doing so there is less stress on the rudder and rudder servo. Also if the plane has to ditch because of dead stick with gear up the tail wheel is not going to pull out of the rudder or damage the rudder.
(there I go giving up secrets... darn it).
Skids
