RCU Forums - View Single Post - 5SC steering problem
Old 03-16-2015 | 05:08 AM
RWTDCT
Originally Posted by phmaximus
Are u sure about that??? I think that's a 1/10 servo where the steering uses a 1/5 servo
The stock HPI servo is 25kg/cm where that is only 16kg/cm
personally I think he would be best using one of those 40kg/cm servos that come in the baja clones...
Ive personally used one in a Losi 5ive and the Losi considerably heavier with 4x4 so the steering is a lot heavier.
here is a video I made to prove it works
http://youtu.be/Y-3CZaQtJa8
I bought the Savox SV-0235MG High Voltage 5th Scale Digital Steering Servo. Also a Hitec HS-5645MG Digital Throttle Servo w/ Metal Gears .
