5SC steering problem
Old 03-15-2015 | 05:58 AM
Default 5SC steering problem
HPI Baja 5SC
I noticed using my radio to turn the steering - while sitting on the ground it turns full to the left and only partially to the right, also while in motion. (I usd adjustments on the radio to center steering). If I pick the front end up off the ground it turns full both ways left and right. I disconnected the linkage, everything turns smooth (no binding). Could it be a bad servo?
What's you thoughts?
Old 03-15-2015 | 07:00 AM
collector1231's Avatar
Moderator
Because the servo is not powerful enough to actually turn the wheels at a stand still. Like we said, get other servos.
Old 03-15-2015 | 05:00 PM
phmaximus's Avatar
Be careful dry steering..... U will overheat the servo if u try to turn with out moving... 1/5 is nothing like 1/10
Old 03-15-2015 | 05:22 PM
So, what is the best steering servo to get?
Old 03-15-2015 | 06:07 PM
Moderator
Like I've posted before, this will work well; http://www.atomikrc.com/collections/...-digital-servo
Old 03-15-2015 | 06:10 PM
nitroexpress's Avatar
You didn't mention a budget. Big bucks. But you have a big vehicle. So go large.
http://hitecrcd.com/products/servos/...servos/product
Old 03-15-2015 | 06:16 PM
lol, I don't mind spending a little money, but not to the extreme. I did find a Savox-0235MG. How does this compare to the HD-9150MG?
Old 03-15-2015 | 06:55 PM
Moderator
Any metal geared high torque servo will be fine for the Baja.
Old 03-16-2015 | 03:44 AM
phmaximus's Avatar
Are u sure about that??? I think that's a 1/10 servo where the steering uses a 1/5 servo
The stock HPI servo is 25kg/cm where that is only 16kg/cm
personally I think he would be best using one of those 40kg/cm servos that come in the baja clones...
Ive personally used one in a Losi 5ive and the Losi considerably heavier with 4x4 so the steering is a lot heavier.
here is a video I made to prove it works
http://youtu.be/Y-3CZaQtJa8
Old 03-16-2015 | 05:08 AM
I bought the Savox SV-0235MG High Voltage 5th Scale Digital Steering Servo. Also a Hitec HS-5645MG Digital Throttle Servo w/ Metal Gears .
Old 03-16-2015 | 02:36 PM
Why did Hitec feel the need to bring out their 1208oz servo? Because for hard bashing and racing, nothing else worked. Dual servo setups worked, but were about as expensive and more complicated.
http://www.davesmotors.com/HRC34900-...ve-HT900K.html
http://www.nitrohouse.com/Losi-5ive-...x_p_15905.html
