RE: Homie 25 Throttle spring????????/
what ever you do donot remove the spring it holds it at center bore against the retaining ring on oposite end,you can cut off the hook that returns it but you need the tension to pull it out or else it wil wear and cause eratic idle and sticking over time.
Darin
