RCU Forums - View Single Post - The New Pentathlon Evolution
Old 03-21-2015 | 01:15 PM
  #156
rm's Avatar
rm
My Feedback: (27)
Hi Mark,
Here's some pics of my evo with the OS installed.
Remember it has over 300 flights on it and its been bashed for different setups.
I've lengthened the pipe tunnel to try out the escoposites pipe. Currently I'm moving all my servos to the tail to try out the cg where you fly it at on the back of the tube.
Motor is hard mounted without a nose ring on 1.75" extensions. I didn't want to use a soft mount, coming from imac way back when, I'm use to this type setup. Being all wood/foam construction, it's worked well without any header problems, loose bolts, etc. Used the YS firewall. OS with the extensions pretty much matches the length of the ys on hyde mount so it basically dropped in. Tilted motor slightly which allows the header to be completely inside chin.
Covered monokote, painted canopy and chin. Wt should be around 10lbs, 8oz now with the OS plug, 1100mah life.
ID:	2083003   Click image for larger version
ID:	2083004   Click image for larger version
ID:	2083005   Click image for larger version
ID:	2083006   Click image for larger version
ID:	2083010   Click image for larger version
ID:	2083011   Click image for larger version
