Part Two:
The motor leads were not long enough to reach inside the fuse, so I had to solder extensions on. I also soldered 4mm bullet connectors on the leads and the ESC. Shrink tubing was used on all solder joints also.
Now Ive got everything plugged in and Im ready to bind the receiver to my FrSky Taranis Plus !
Everything is mounted with two sided adhesive vel-cro.
Last but not least, a wheel upgrade. I used Dubro 3" wheels for grass landings.
The telemetry is all set up for my receiver voltage and RSSI. I have voice alerts set to alert me of impending doom.
