Originally Posted by
dbsonic
Ron, Mine has the 2 sides into a common header then into a UAT and works great for probably 100 flights now on K180. The 2 sides are 1/2 gallon each and my header is not that big but you could go with a 32oz and that would be a good setup. I think the header helps provide a good sized reservoir to help regulate any difference in flow from the 2 sides. Worth trying.
That's basically the same setup I am using, I have the two saddles going into the main, and the main is going into this UAT
http://www.dreamworksrc.com/catalog/...ap-Large-260Ml
,, I am going to swap to the BVM high flow sock style Uat and see if that works better,,I will pressure check the whole system again. I have the turbine out and will be sending it to KT to be checked this week I am really hoping they find a problem
