RCU Forums - View Single Post - Lets build a tank!!! The tamiya JS-2
Old 04-01-2015 | 12:02 PM
  #87
ausf's Avatar
ausf
Originally Posted by Rustytrax
Have you battled with it at Brets? Normally I would agree about tracks, but once installed I never again had a traction issue with the IS. Danville has a very well groomed surface and stock tracks work ok there. It was once the terrain gets loose debris.
I battled it with Bret at NEAD, but not as his place. I've used it on grass, gravel and dirt around with no traction problems whatsoever. This is first I recall hearing about them having traction issues.
Why do you get better traction with metal tracks? Is it a different link pattern or more ground pressure?
