Originally Posted by
Rustytrax
I have KZ1 metal tracks from MATO on mine. I found they added the weight the tank needs. The IS2 is so long and has such wide tracks it has very little ground pressure. As a result the tank would spin the tracks and not move on slight hills.
Since you have one now I'll bring mine back to Danville so you have a battle buddy.
Sounds good. I didn't buy the metal tracks, but I can see where it would be a good option. I'll give it at least one time with the plastic and if it just doesn't work out like I hope then i'll buy a set of the metal ones.
