RCU Forums - View Single Post - Covering This Wingtip??
Old 04-02-2015 | 09:36 AM
Gray Beard
My Feedback: (-1)
Thanks, I had to repair both wing halves and removed only the bottom covering, I wanted to keep the graphics they have on the top. I have covered two planes with the Chinakote and found it goes on even better then Ultra. I had both planes out with me a couple times with the temps close to 90 degrees and like Ultra is doesn't sag or wrinkle in the heat. I'm very impressed with it and will now be using it exclusively from now on. Like Ultra the white glue that will squish out if too hot or too much pressure is used is removed with a rag and acetone.
This is the first time I have used the Ultra clear tinted covering and was also impressed with it too. Went down easy and shrunk well.
