RCU Forums - View Single Post - Mounting props to backplates with spinners
Old 04-02-2015 | 07:50 PM
52larry52
Only the center hub area of the prop should contact the spinner back plate, not the blades of the prop. If they do, use a different prop. The backside of the prop contacting the lip of the spinner back plate will create a prop failure point. A minor notching of the back plate lip might be OK, but never notch or modify the prop to clear, modify the spinner openings, or use a different prop. (or a different spinner)
