RCU Forums - View Single Post - Covering This Wingtip??
Old 04-03-2015 | 09:20 AM
jester_s1
Moderator
If you will do what I described, you will get a smooth finish. The trick is to stretch it along the line where you are attaching it to the existing covering. That will pull the wrinkle out of that tight compound curve at the front. It won't pull all of it out, but it will pull it enough that a secondary shrink will finish the job.
