I have TBS going to a 15Watt amp from Dan. the only connection that i made from the TBS to the Amp was the signal out to the amp. Now with that being said the amp also works off of it's own power. what i mean is the amp is drawing it's voltage direct from the battery. So the only connection that i needed was the signal. Now if your running an amp that is slaving it power from another devise then you might have to connect more connections. As far as the speaker itself it just plugs into the + and - terminals.
Now with all that being said I am not using a Clark. I'm using the BARC4. But i would imagine that if your amp is running on it's own power source that the hook up would be the same as mine.
Bill
