So are you only going to use the TBS to deliver sound to two speakers? The amps I sell have outputs for two speakers. So just one wire from the TBS to the AMP, and then you can have two speakers tied into the amp.
If you are paralleling the TBS LS out, you probably need to be concerned about over driving the on board amp. it might be safer to run it in series with your existing speaker.
