Originally Posted by
MAVROS
TonyF,
Just wondering if you have any overheating issues with your YS......it looks to me that the air intake area is far too small
kind regards
Mavros
The exit area treatment has as much to do with cooling as inlet area does. So does ducting around the engine. If the cowl is done right, with a duct immediately behind the inlet in the cowl, the inlet should work okay in most climates. It's surprising how little it really takes. Very hot climates (Arizona, Texas) may present a problem in the Summer.
