RCU Forums - View Single Post - Covering This Wingtip??
Old 04-10-2015 | 02:36 PM
  #39
CModel
Grey,
This may sound odd, but now the only issue is I keep getting the color separating from when I shrink the leading edges compound curve. I can get it drum tight, and perfect, but around the edge of the tip it appears the covering is under, so much stress from shrinking its breaking the pattern of black, and white checkered Ultra Coat like color separation, but with no wrinkles. I'm not sure if I'm actually shrinking it to much, or missing an application technique. Other than the solid wood edge of the tip where the severe compound curve is at the leading edge the rest of the tip comes out perfect.
I'm not sure if I'm just splitting hairs, or if I can try a different method.
