Originally Posted by
jsanchez581
Thank you Tony... you did an outstanding job with your bird. Please fell free to give me any tips.
Thanks, what are you using to sheet the wings, stab and rudder, glue and balsa thickness?
I also would recommend a paper tube for wires if you haven't already done this. The DLE55 is perfect for this and when I build my third as a super chipmunk I may squeeze a 61 in it. I would pin the side ply on your gear bays with dowels into the foam, otherwise your doing good.
TB
