RCU Forums - View Single Post - Stuck contrapistons???
Old 04-11-2015 | 04:23 PM
qazimoto
Originally Posted by Warren B
A method I use is a pedestal drill used as press.
With the barrel removed and placed on a suitable block, use a short piece of rod in the chuck and push the contra to the top of the bore from below, then reverse and push it down again.
A dozen or so cycles often does the trick.
... and keep adding oil.
