Originally Posted by
sergeantseabass
To turn on the lights you have to use the turret rotation stick and trim set to max. I'm working on painting mine right now So I can't remember which way you move it. Also make sure that both plugs are in the MFU. the three pin and two pin. They should be seated one above the other.
If that doesn't work you can hook up a 3V supply directly to the LED and see if it powers.
Hope this helps
Bill
Thanks for the replies. Bill, I didn't know that the two pin had to be plugged in. In fact, I didn't see a place to plug it in. the instructions say the red LED will not be used so I figured it didn't need to be plugged in. What I thought was a void right below the 3 pin, actually had a dummy plug in it. I pulled the dummy plug and inserted the 2 pin and let there be light. Moving the left stick to the right after sliding the trim to the right turns them on and off. Thanks for the help guys.
